It is currently Sat Jul 19, 2025 4:40 pm
PostPosted: Sat Nov 18, 2006 8:24 am
Hi All
Is there any job once started on your build that you must finish once you begin it?? Mostly cause of wood movement or glue? Since I'll be working on my project in the evenings and on the weekends, I'll be doing a little at a time. What are some of your experiences?
PostPosted: Sat Nov 18, 2006 8:33 am
Get sides done first ready to recieve the back and top. I prefer not to let the tops and backs set around to long after being braced up.
PostPosted: Sat Nov 18, 2006 8:34 am
1 - get a top or back completely braced in a day at most - you want the humidity levels to NOT change.
2- if you bowl sand the top or back for final fitting, do NOT remove it from the mold until the top or back is glued on - you pretty much cant get it EXACTLY in the same spot if you take it out.
PostPosted: Sat Nov 18, 2006 9:37 am
good question!
Charliewood
PostPosted: Sat Nov 18, 2006 10:42 am
Bending the sides of course and making the kerfed linings, kerfed linings making is just sooo repetitive that you have to finish it once started and stay concentrated because you could fall asleep on the table saw!
glueing up with HHG is another thing IMO.
PostPosted: Sat Nov 18, 2006 8:36 pm
First name: Martin
Last Name: Edwards
I try to get the whole thing built in one day.......
Seriously, the bracing and the top & back onto the sides as soon as is practical. Don't leave a top for 6 months unnattached to sidesmartinedwards39040.1920601852
PostPosted: Sat Nov 18, 2006 11:59 pm
I braced four tops, three sat around while I finished the guitar on one. By the time I was done the other three had turned into giant potato chips.
I now attach sides soon after bracing the top.
